Volvo Penta 5.0 GLBY engine with SX-M Sterndrive.
Engine starts every time with no problem after a while in neutral stalls. I have taking it in the water and could run fine at different speeds with no problem but then suddenly it stalls and dies. It starts right up and runs for another while and does the same.
How can I troubleshoot myself PLEASE!!!, I have spent over $6k now everytime the dealer works on it the problem dissapears for a while and then comes back.
here are the things they have worked on so far;
1. Changed distributor cap, rotor and cables.
2. Did a compression test (tested out ok).
3. They checked the fuel tank. (good and clean).
4. They did a Fuel system test (no restriction, good fuel flow).
5. Shift cable was corroded, (replaced).
6. Several cables studs or terminals corroded (replaced).
7. Replaced carburator kit.
8. Volvo Penta 5.0 GLBY engine with SX-M Sterndrive. Engine was stalling and backfiring. I took the boat to the authorized dealer and they did several things;
Should I start from scratch myself. What should I do?
Any help greatly appreciated as always.
Thanks.
Carlos
Thanks.
Carlos
