pennyanman
- Jun 12, 2002
- 42
I am probably being anal about this one (as engineers are known to be anyway..), but here goes; <br /><br />When under way, there is warm water exiting the front of the two piece plastic cover under the engine pan. The pan area under the powerhead stays dry. I also notice when running the muffs in the driveway that some warm water is discharging from the lower unit mounts that attach to the exhaust housing. I don't recall seeing this on either of my older OMC V4s.<br /><br />Any ideas? Is it anything to worry about? The previous owner changed the water pump. Is it possible he left out a gasket or the exhaust housing lower grommet?
