I have a '95 Bryant 209 with a 7.4 Bravo I. I've been loosing gear lube slowly for a few years. I never see water in the oil and last year I pulled the drive and replaced the prop seals, the prop shaft bearing housing seal, the seal that mates the lower housing to the upper, the drain pump o-rings, the seals that go between the outdrive and the gimbal housing, as well as the seal that goes under the top cover of the shift housing. I never see any oil leaking inside the boat or out, but I seem to lose about 3/4 of the reservoir throughout the summer. I just tried pressure testing the outdrive and it's been holding a steady 12 lbs for the last two hours. I am really stumped.
Please, please share your advice.
Thanks,
Jim
Thanks,
Jim
