Re: Connecting a Tach to my 78 Johnson 115
The tachometer operates off of the engine's charging system. A the engine's wiring terminal strip, a gray wire is attached to the screw terminal that leads to a yellow wire that leads to the rectifier. This gray wire is the sending unit so to speak (sensor wire). This gray wire continues on thru ther wiring harness up to the control box and instrument panel where it can easily be attached to the tachometer.
The tachometer that you mentioned in a previous post should work. However, the proper tachometer would be one that would operate off of a 6 pulse charging system, which your engine has. The tach would have a dial on the back of it which you would set to number six (6).
