new to boating,and iboats.thanks up front for any advice.heres what i just inherited,17 footer sangster with 3.0L mercrusier LX eng serial ok155627 drive serial ok250933 motor is fwc and full of antifreeze. po was mechanic so was well maintained. problem water in oil and mixed.took water hoses off motor all fittings clean and antifreeze present,pulled hose off exhaust manifold rust and so plugged cant force any water through.now do i pull motor all apart or could rusted out manifold be problem.i now you guys arnt looking at it but is it possible,if it is then i will buy compression tester if not its junk.anyone no hp rating,year
