I am working on an 1985 Evinrude 9.9 that has overheated and started to smoke. It was shut down. Looks like it was hot enough to start paint peeling at the top of the cylinder head.
It is pumping water through, although the stream is not as strong as on some I have worked on. I replaced the water pump impellers (I think the original was indeed okay) but found the grommet from the pump to the copper water line chipped away, so I thought this was leaking water right back into the exhaust housing, not making it up into the engine. Replaced the grommet.
Running at low speed in a barrel, the temperature remains reasonable. I can put my hand on a warm-to-the-touch block.
I put the engine back on the boat and took it out for high a high speed run. It still wants to overheat. Touching the block after high speed? It is very hot to the touch. The water coming out of the exhaust is hot. The water coming out of the tell-tale is just warm.
So, Do you think I am to the point where I have to pull the power head and check the complete water path from copper tube into the block? I am afraid of this for I do not want to break any bolts ....
Does anything else come to mind that I am overlooking?
Thank you,
J
Thank you,
J
