1995 130 Johnson carb leak...
Miakid22
Having a leak through the bottom little hole of the bottom right carb...a good amount a little gas comes Out. Any suggestions ? Boat had been sitting for a couple months before me buying it.
Dhadley
Re: 1995 130 Johnson carb leak...
Most likely you have a stuck float and/or a collapsed needle. Basically a good cleaning of all the carbs will probably cure the problem.
