Re: gimbal bearing removal question
Try an eBay search for either '3 jaw puller' or 'slide hammer kit'... I just did, and there are thousands available and they won't break the bank. Do you have the Merc service manual for the drive? I think the one for you would be either #2, #4 or #6, depending on the year of the engine/drive.
homemade tool even easier heavy flat plate to go across the bell housing flat plate across the back of the gimbal bearing between the bearing and the seal both with a hole in the centre for a length of threaded rod to go through couple of nuts locked together on one end pass it through the 2 plates so the locked nuts come up against the plate behind the bearing spin another nut up to the plate at the bell housing keep turning bearing falls out
Here's that paragraph again, only this time with punctuation, you'll find it much easier to read.... (get the hint?) Homemade tool? Even easier. Heavy flat plate to go across the bell housing, flat plate across the back of the gimbal bearing (between the bearing and the seal), both with a hole in the centre for a length of threaded rod to go through. Couple of nuts locked together on one end, pass it through the 2 plates so the locked nuts come up against the plate behind the bearing, spin another nut up to the plate at the bell housing, keep turning, bearing falls out.....
Chris.........
