Re: Muffs
I had a similar problem w/my 30 HP Mariner. I had just had it serviced, including new impeller. It sat for a couple of months, and when I fired it up - no water through the tell-tale. Called up the guy who did the repair work and he suggested that the pump wasn't priming on the muffs.
Solution: I turned on the water and squeezed the muffs against the lower housing, so almost all of the flow was forced through the water intake, until I heard water gurgling inside. Started the motor and, bingo. Good flow through the tell-tale.
Apparently if it sits for awhile all of the water drains out of the lower unit, including the impeller housing, and the pump needs to be re-priimed.
