I have a 2011 bayliner 18.5br. I was trying to install an amplifier and Hooked up the RCA cable to the wrong side of the radio and shorted out the radio/amp/and now the ignition does not have any power. All of the fuses are intact on the power block. I had direct power from the amp to the battery via 8g wires. I cannot find a blown fuse. I removed all power and cables from the amp; however, I still do not have any power to the ignition. the blower works, horn, trim tilt, and lights. The ignition does not start or turn on at all. Where do I look? Is the wiring a inline fuse, are the ignition and the sterio on the same line? Is there an Inline fuse Where would it be? I have looked and cannot find it. Please help!!
Thanks
John
Thanks
John
