Re: 1982 mariner 60hp problems
not sure on the question but if it's the trim no going up only down, does the sol. click when you press the up switch? if so it's probably a bad sol. on the tilt unit that should be the same hydraulic setup my 50 has. one of my sol. didn't work well at first just clicked. try jiggling the switch off and on a few times. the sol. will green up when sitting and sometimes hitting repeatedly a few times will break through. my has cleared up since I started using it.
