waterman556
- Sep 22, 2008
- 13
Working on a 1976 75HP evinrude model #75643D. Water is coming from around the front of the exhaust adaptor at the front of the motor.The water flow is good pee stream is strong. Dropped the lower unit and water tube is really loose . Blew all the outlets out to just be sure so everything seems to be open.I have searched the forum and cant find any mention on how to replace this seal if the seal is the problem.I have read my omc service manual and no luck there it just says remove. Just hoping that its a pull out of the water tube and seal.I just dont want to tear up something .Any help will be deeply appreciate and thanks in advance. Randy
