Replacement Cover For Bennington
deepcreekjohn
Hi All,
Looking for a replacement cover for my 2003 Bennington 2075. Has anyone come across a good source? Does anyone know if the factory sells them direct? Thanks
Jeep Man
Re: Replacement Cover For Bennington
Welcome aboard John. Any local top maker or marine upholsterer could make a replacement for you. Sunbrella will be your best material and you existing cover will be handy for measurements. Most mfgs. usually keep stock for models up to 5 yrs. old. The question would be is if a cover from a newer model fit yours. As 5150 works at the Bennington factory, I'm sure he will chime in for more accurate info. Also there are companies on line such as Dowco that make covers for different manufacturers and sell to the public as well.
5150abf
Call your dealer and they should be able to set you up, Bennington deals with the dealers and your dcealer deals with you they don't sell directly to the public.
