85 merc thunderbolt with high voltage problem
dirtydog
85hp thunderbolt ser.# 4095472 has 16 to 18 volts output I replaced the rectifier but didnt help. mechcanics wont work on it do to the distribitor, could the stator be the problem? can it be ohmed out?:confused:
stickerhard
Re: 85 merc thunderbolt with high voltage problem
are you using a sealed battery?
Barnacle_Bill
Make sure all your battery cable connections are clean and tight. Be sure you are using a marine battery and not a car battery. I've heard tell of some people using This with success.
