Re: volts reading about 18
14.5 to 15 volts is ok. It is not going burn up your radios, GPS, or depthfinders. Many newer alternator do charge up to 15 volts and they work fine. In fact I think most new alternators charge to 14.4. Older alternators only charged to about 13.8 volts.<br />Alternator on my truck charges to 15 volts when it is cold. I though this was too high so was doing some checks and reading thru the factory theory manual. In the manual said when the temperature is cold will charge to 15 volts as it warms up the voltage drops to 14.5 volts. At that time I put the meter and tools away and got a refreshing drink.
