beason
- Mar 15, 2011
- 338
I found a guy local that has done all the things on his boat, that i need done on my boat, with the exception of the gimbal bearing and impeller. He even has the special tools needed with the exception of the alignment tool.
Do i need this? I thought i did, but ive also heard that it is only used when installing the motor.
I plan to do these things
gimbal bearing
shift cable kit (linakge, bellows, etc, also includes gimbal housing seal?)
exhaust bellows
driveshaft bellows
shift shaft seal
water impeller
I also heard i need bellows cement.
Anything im missing?
I heard i have to split the lower to change the impeller, that means i have to refill it with oil. that means i need the oil pump? can i turn it upside down and fill it that way? I guess im lost as to why i need to fill it from the bottom.
gimbal bearing
exhaust bellows
driveshaft bellows
shift shaft seal
water impeller
