I have twin 3l glp c petrol engines (2004) in a fairline mirage with SX outdrives. Boat had been working well with some longish trips. Then my son went to start the port engine and it turned over and caught until ignition released and then it died. After recharging the battery and with some advice from Don I traced the fault to a fuse. However now the engine runs rough, is hard to start and backfires. On tickover it can run for 20mins or more and will rev high in neutral but under any load the revs die and the engine cuts out, often with a backfire. Could the blown fuse be related to some other electrical problem causing these symptoms. Until the fuse blew the engine ran well.
Meanwhile on the starboard engine I have suddenly started getting very high oil pressure (off the scale) when I increase the revs. I have a leaking raw water pump (water getting past the seal and into the housing) and I know I ned to renew the pump. I have checked to see if there is water in the oil but it is fine and the oil level is normal. Could the leaky water pump generate the high oil pressure? In addition the trim gauge is reading fully up when the sterndrive is in the down position and the trim switch has stopped working.
All these problems seem to have occured at once. So I am inclined to think the high oil pressure, the trim gauge reading and the failed trim switch plus the problems with the other engine are all related. I just find it strange though that it is the guages on one engine and the poor starting on the other that has occured together. Perhaps just coincidence.
Any help greatly recieved
