Hello All,
I am in desperate need of some help, I have a 1988 Bass Tracker with a 60 HP Johnson that I purchased this last spring, I had it out about 5 times on the initial tank of gas that the previous owner had in it...
After trip number 5 I ran it dry....I refilled and did NOT realize the previous owner had Bi-passed the VRO system and now adding the oil to gas was required.... I however didnt realize this until later, after running about 1/4 to 1/3 tank thru it....The engine would die if throttled past no wake speed I was getting very very frustrated trying to figure out what was wrong.... of course its always the last thing you check right?
I have now replaced the sparkplugs, Drained the carbs and blew canned air thru all orifices and filled and replaced the gas with a 50 to 1 mixture.... Fire it up on the muffs and it sounded better but was smoking a ton and the idle RPMS were at about 2000 and after about 20 sec or so I could here them ramping up they kept ramping more and more to where I had to kill the engine around 4000 or they would have kept climbing.... I noticed that i had opened the solenoid valve to be perpendicular when I was working on it earlier but being a novice I dont know which way is normal?!?!
I checked the plugs after this and they were very oily and I also noticed excess gas coming out the front of the carbs almost a greenish color, I also realized that I overdid my mixture a bit, I have a 7 gallon tank and I added the 50 to 1 mixture for that amt of gas even though I only had about 5.5 gallons in, so that might explain the smoke, I have since then balanced out the mixture.....
The Seloc guide says that there should be a low speed adjustment arm, but I for the life of me cannot find it... I HAVE checked the compression and its fine, I wrote the numbers down but dont have them with me.....
can someone please provide some insight on where to go next?!?! I am complete novice working on Outboards.... and please understand that when I say novice I mean I am very green...... so be nice Thanks in Advance!!!
