X2. The brake fluid might have damaged the seals, you might get lucky though.Welcome to iboats.
Remove the drain plug and drain it.
Open the relief valve and lift and release the motor by hand and re-fill the cylinder and do it 2 or 3 times to flush it out.
Is the trim motor running?
