Re: 1967 65hp mercury water pump replacement ?
Undo bolt that holds the trim tab on (12pt or 5/16 Allen head), remove the bolt under Trim tab,remove nuts on underside,remove nut at front top of LU, loosen the nuts at the top side of
LU and alternately undo them until LU drops onto something soft.
