I purchased a 1979 Evinrude 9.9 2-stroke outboard, model 10924B, serial#06656 this summer. I replaced the plugs, changed the gear oil, ran it with new fuel. Started on the second pull, accelerates and planes nicely. That was earlier in the summer.
Now, out of the blue, something odd is happening...I started it right up a few weeks ago - but it wouldn't accelerate. I turn the throttle and it just either bogs out or stays at a very low speed, RPM. I put in new plugs (the newer Champion version of what the outboard recommends, as they do not make the older ones) and it has plenty of oil/gas, etc. I had a compression test done and it all checked out fine.
Additionally, I cleaned the carb (which was dirty), replaced the fuel pump (since the diaphragms were all torn) and still am having the issue. When I run it forward or in neutral in the tank, it seems to run fine. It's just when I get it out on the water, I put it into forward, accelerate, and it won't - it might for 2 or 3 seconds then just bog down to about quarter speed, then accelerate, then bog down again.
What would caused this motor to all of the sudden just not be able to accelerate and get gas? The gas bulb is firm when running and the lines/hoses are all secure. Thoughts??? Am I losing my mind? Could it be the gas tank, the line? No idea guys, no idea.
I've included a link of a youtube video showing you the issue...towards the end of the video when I am going real slow the throttle is actually gunned all the way.
http://youtu.be/mSVgryG4FdE
Thanks for any help!
