Lostfisher
- Nov 2, 2009
- 147
I have a 1988 15 hp johnson. I just got the motor and it was overheating after I would run it full throttle for a few minutes. The tell tale turned into steam. So I put in a new impellar the old one was bad I peed better but still had the same problem. I than pulled the powerhead and cleaned out the cooling system there was a blocked port about1/8th in dia. that was totally clogged. I also checked to see if the exhaust was leaking into the cooling system it wasn't. Put everything backtogetherruns great pushes water fine I can go high speed fine but when i lower my rpm the pee stream turns back into steam and I have to turn the motor off and start it up again at an idle to get the pee stream back. The motor does not have a thermostat and i was told that this might be the problem to my overheating because it needs the back pressure of the Tstat in order for it to cool properly. I would like to get some conformation before I dump even more cash into this motor.
