Speakrdude
Ensign
- Feb 25, 2004
- 942
After searching, I have found the source of the water intrusion. Its is a gap on the top side of the port drive. Not very big, but big enough I suppose to let water past. The way I found was to (obviously) smear some 5200 over it. Leak stopped.
Where the small gap is, the fiberglass seems to be sunken in just a bit. Does this sound like a rot issue? All seems to sound very solid.
Directly behind that area, the inner transom plate is in the way of drilling a core sample.
I believe the way it started leaking was, when I sanded the bottom paint away from the drive. I must have removed some sealer the PO had there.
Any ideas, solutions, remedies?
jim
jim
