I have a 1976 175 OMC stern drive. I had to replace the forward shift coil, when I was putting it back together I noticed that the driveshaft didn't turn easy, it seems to be rubbing against the nylon fron the lock nut. The gears spin fine no binding if the driveshaft isn't in, but once I put the drive shaft in it binds and I have to use wrenchs to spin the Driveshaft. Any advice would be great.
Thanks Brandon
Thanks Brandon
