thebarnacle
- Jul 7, 2011
- 9
I have a Yamaha F80AET Q 2003 OUTBOARD four stroke, lost tilt & start, keeps blowing the 30amp fuse. With battery disconnected and tester on the 30amp fuse red lead[disconnected from starter relay]& testing ground lead to engine block the circuit is Open, where may I look next, appreciate some guidance. Starter motor works & Starter relay
seems okay, that is when disconnected & tested to positive to Neg it is not an open circuit & no resistance indicated,
