I am new to boating so I hope this is a quick fix.
The motor starts up fine with the muffs on it,but when I get in the water it is hard to start and when it does
start it does not want to idle. If it stays running I can put it in forward and it will run great at low speed and
high speed.
I changed all of the coils (cracked) and plugs and the power pack before I ever put it on the water.
Like I said running slow it runs good and if I give it full throttle it runs fast and smooth and then when I cut it
off I have to choke it and give it full throttle with the warm up lever in order to start it.
I would be thankful for any help.
Weasle,
high speed.
Weasle,
