mrsaundep
- Jun 9, 2009
- 55
Mercruiser, MCM 140, Serial number 5568367, Alpha 1, Serial number OB656591
I removed, overhauled and refitted the engine and sterndrive myself after a core plug blew out behind the flywheel. Fitted loads of new parts (including a new core plug ofcourse), incl. bottom end bearings, piston rings, overhauled the cylinder head, all new gaskets where disturbed, tune up kit (new plugs, points, condenser, rotor etc, water pump. Compression test after OH was good; 138, 135, 138 & 132 psi. It was hard too start but once warm was fine. Shifted ahead and astern fine. Launched boat and adjusted shift cables/shift cut out afloat, undertook a tune up, checked timing with timing gun, all seemed good.
I have since put 16 running hours on the engine. All pretty good but problematic running at low revs. Everything is fine over 1000 rpm and have had her up to 3000rpm for a short while all fine. She is difficult to start until warm. Once warm the idle speed is sometimes erratic. By that I mean sometimes when I shift to Neutral its at a steady 800rpm, at other times it idles at 450-500rpm in neutral, and often stalls when shifting, especially into astern. I cannot adjust the idle speed, adjusting the idle screws on the carb have little / no effect.
I have pulled and inspected the plugs again, and the H.T leads (which were renewed with Merc leads 2 years ago) and all are are good.
Fuel is fresh and watre free.
I am thinking that the carb needs an overhaul as it the only think I did nothing to it (other than clean the fine filter on the carb fuel intake, the spark arrester, and fitted a new gasket between Carb and manifold).
Any other ideas to check out?
Tks in advance, Paul
