Re: 1964 Starcraft Slight rebuild
LOL sorry I meant to say Foam it's this stupid auto correct lol.. I bet you thought I was nut
I was just thinking, "what the heck is this guy trying to do?" Then ran across this post. LOL!! That's funny.
When you lifted the bow up, how long did the boat drain water? if only for a moment or two, then you're likely okay - especially if the front end is much lighter now. You always want to store it with a bow up attitude and the plug out so water can escape.
Once it's done draining, look from the inside of the boat into the bilge. You should have an empty "box" like area at the very back of the boat, and at the bottom of that "box" on the transom should be the drain hole you plulled the plug from. I don't know what type of "lever" would be there - UNLESS, you haven't pulled the plug and it's plugged from the inside. If that's the case, that little lever is probably the release for the plug. That bilge area get's all full of crud and corruption when a boat has been sitting for a long time. a good shop vac back there might be a good idea.
If you've got no soft spots in the floor, the boat drains water and isn't too heavy to lift the bow up and you are confident the transom is solid ... you've got a nice project on your hands. Hope it goes well for you.
