Just installed a 1989 long block reman . It's a Gm 350 5.7 Omc set up it has the petronix ignition set up. The motor has the flat tappet lifters. I set the timing at 10 btdc the total is 32 and I'm burning 93 octane gas . Do these numbers sound right ? The motor does run well . If I move the throttle too quickly there's a slight bog with the Rochester quadrajet
