Hi All,
Im starting this thread just to give you all a bit of what worked and what didnt for my hull restoration project.
Situation: Faded marroon flake, turned silver. Most topside clear gel has actually faded/disintergrated away.
Assesment: Either Paint, or new gelcoat.
Decision: best to gel coat....from most i have spoken with. I will also re-flake with red.
Steps (This part is a "Best Of" all the advice I have gotten.)
1. Fill, fix, and sand all areas with 80 grit that will recive new gel.
2. Clean with soap and water.
3. Wipe down entire are with acetone prior to first coat.
4. Tape and mask.
5. Apply first coat - Red base gel coat.
- Gun 2.4mm tip HVLP
- Thin 5% with Duratec Thinner 39LAC
- Catalize with 2% MEKP-MCP (slower cat than MEKP-9, 2x pot life)
- Apply around 5mil
- No Surfacing Agent i.e. wax
- Let dry 2 hours
6. Apply second coat - Clear gel w/ Red .015 hex flake mixed in.
- Apply around 5mil
- Mix in tested amount of flake ... guessing 10g per ounce of gel.... still need to test spray when materials arrive.
- Let dry 2 hours
7. Apply Third coat - Clear gel w/ Red .015 hex flake mixed in. ** possible second coat of flake clear if coverage is light **
- Apply around 5mil
** Mix in tested amount of flake ... guessing 10g per ounce of gel.... still need to test spray when materials arrive.
- Let dry 2 hours
8. Apply Third / fourth coat - Clear Gel
- Apply around 10mil
- Let dry 2 hours
9. Apply Fourth / fifth coat - Clear Gel
- Surfacing wax added
10. Pull Tape and paper.
11. Let harden atleast 24 hours
12. Sand area with 180 / 220 depending on situation ( try to smooth out any orange peel on visible areas and put a tooth in all others.)
13. Clean with soap and water.
14. wipe with acetone.
15. Re-Tape and Mask
16. Apply Final coat - Clear Gel
- Mix 50/50 with Duratec clear gloss additive
- NO Surfacing wax added
17. Let Harden for extended period..... 2-3 days?
18. Polish with Porter cable 7424XP Orbital Polisher/Buffer.
- use swirl remover
- glazing compund
- No wax?? I heard that wax actually promotes the hazing boats get over time if not removed and redone frequently.
- Add some kind of sealant, have not researched this yet.
19. Hope Im done...buy a nice boat cover!!!!!
I will add pictures from this point on so you guys get some sense of what a new boat owner/DIYer does to destroy his boat!
If anyone has advice please pass on, I need it!
I will also update you as progress happens. I plan on starting the Gel on Oct 15th, 2011...weather permitting.
Thanks!!!
4. Tape and mask.
- Apply around 5mil
- Let dry 2 hours
- Apply around 5mil
- Let dry 2 hours
- Apply around 5mil
- Let dry 2 hours
- Let dry 2 hours
- use swirl remover
- glazing compund
Thanks!!!
