Hi I have a evinrude 1982 E8RCNR 7.5hp engine.
having a big problem with it right now its a bit temperamental. its just had a new impellor, plugs, gaskets and new drive shaft bearings and seals, basically a full rebuild last week and tested it today.
The problem is, is that it usually starts first few pulls after you begin your trip (or at home) and then after 2-3 miles we usually stop for some fishing etc.
Well getting it started again was a nightmare, even when the engine had fully cooled, but it doesnt really get hot.
apart from this starting issue it runs fantastic.
to get it started again i checked plugs/spark and then poured some fuel down the plug holes, this worked the first time but still took 10 pulls. The second time this would not work and had to row about half a mile, although it did try to fire several times, but not instantly after the fuel was put down the barrel and then pull cord snapped after about 50 pulls.
I'm really baffled I thought it was a fuel problem, as i know the bulb doesnt go rockhard. you can squeeze it for ever so i was thinking that, but why wouldn't it fire with petrol in the barrel. I'm releatively new to engines... maybe theres something im missing? could it be flooding it some how ? i thought this too but the first time i checked plugs they were dry
will also add i pulled carb pipe off and squezzed the bulb and petrol was flowing through that pipe good.
