chiefcatchemall
- Jul 24, 2009
- 197
Just bought the motor yesterday. Threw it in a trash can and pulled it over. Would run for about 3-5 seconds then pop (backfire) and die. I sprayed some carb cleaner in it and it would stay running longer. The more I sprayed it before pulling it over the longer it would run. Anyways I broke the recoil spring and just went to pick one up. The older guy at the marina said i probably broke it because my flywheel key is sheared? He said its throwing the timing off and causing it to backfire. My first instinct was that my carb is gummed up. The motor hasnt ran in 4 years. Is my flywheel key possibly sheared, or do you think its a gummed up carb? Any input would be VERY much appreciated.
Thanks, Andrew
Thanks, Andrew
