Hello Everyone!
We have a 1976 22ft Searay with a Mercruiser 233 (Ford 351 v8) that is over heating.
We're bypassing outdrive and plugging in hose directly to water inlet. Thermostat housing replaced, water pump replaced, and manifolds and exhaust elbows have been cleaned out.
It will eventually heat up even at idle, and naturally will heat faster at higher RPMs.
My guess is that the hot water is not being pumped or thrown overboard as it should be.
When I touch the hoses that go from the thermostat housing to the exhasut elbows (that is supposed to make water go overboard i think) is relatively cool to the touch, which would explain why it's over heating
if hot water isn't expelled from system. Also, when we disconnect the hoses from the front of the manifolds (the ones that go from FRONT of manifold to thermostat housing),
and just let the water flow out, the boat doesn't overheat (even at high RPMs for extended period of time). So something is happening when water that is cooling manifolds goes back into housing that is causing it to over heat. Can anyone please help me out with what it might be?
Just in case anything doesn't make sense, it might not because I'm a complete amatuer mechanic so sorry about any confusion.
Thanks
Thanks
