some sort of electric shock when battery is plugged, coil is grounded?
peacekeeper6
well i have the volvo penta running again, AQ130 and i was using my ohm meter to get the handle on some loose wires and i found that my coil is grounded. . . why is this? and when i touch my engine i get some sort of tingle like i am being electricuted midly any insights?
peacekeeper6
Re: some sort of electric shock when battery is plugged, coil is grounded?
does no one know why the coil would be grounded?
Dunaruna
Explain "coil is grounded". You said it's running now, yeah?<br /><br />Your getting a shock because there is a short somewhere.<br /><br />Aldo
Ayuh,............<br /><br />A Grounded Coil Won't Fire,........ Keep Looking........
skicat
The engine block is connected to ground. <br /><br />If you connect the positive side 12v to ground you will have a dead short.
Boatin Bob
If the points are closed you will see continuity through the coil back to ground but it won't be zero ohms, it will be whatever the resistance is of the primary winding. Are you using an ohm meter for this or just a continuity checker?
peacekeeper6
but it fires, see i did a continuity test and when i touch the block and the input for the 12+ on the coil they say there is continuity any reason for this? and i dont know where but i seem to be getting some sort of current cause i get a mild shock sometimes, like tingly feeling when i touch the block
chuckz
You will not feel a shock from a 12 volt battery. Do you have AC power hooked up? Are you in the water?
KaGee
Originally posted by Boatin Bob:<br /> If the points are closed you will see continuity through the coil back to ground but it won't be zero ohms, it will be whatever the resistance is of the primary winding. Are you using an ohm meter for this or just a continuity checker?
Depends upon the accuracy of the meter he is using. The resistance would be low anyway, his meter might be showing zero or what he was interpreting as zero ohms.
peacekeeper6
Originally posted by skicat:<br /> The engine block is connected to ground. <br /><br />If you connect the positive side 12v to ground you will have a dead short.
i know the block is ground, but i put one lead on the coil + side and one lead to the block and the OHM meter beeps.
peacekeeper6
Originally posted by L.I. Chuck:<br /> You will not feel a shock from a 12 volt battery. Do you have AC power hooked up? Are you in the water?
its not a shock, just sort of a buzz like feeling, like tingly and no i am not in the water with no AC ground hooked up, maybe its just me and i am interperting the gas burning the cuts on my hands as the "shock" i just dont want to ruin any electrically components with a short.
olbuddyjack
Dude, you sure its not another kinda buzz feeling? :D Theres really not anything there that could shock you other than the coil secondary and it would just bite you not tingle.<br />If your points are closed you'll have a circuit to ground an your meter should beep.
peacekeeper6
ok thanx guys, obviously nothing to worry about
Richard Petersen
A cut in a finger will definately TINGLE. The wet meat and exposed nerves near by make that happen. You are normal.
peacekeeper6
lol glad to know it cylcops. . .
Dunaruna
O/k, I'll throw a spanner in the works,<br /><br />Whether it's a tingle or a ZAP, a shock is a shock. When you are touching the block, YOU (boater dude) are completing (or partially completing) a circuit, that means something is not right - maybe a bad ground somewhere - dunno.<br /><br />As for not being able to be shocked by 12v - it's got nothing to do with voltage, it's the amps. Something is looking for ground and it's finding it through boater-dudes hands.<br /><br /><br />Aldo
peacekeeper6
damn electricty is just using me, no feeling or emotion, i feel so . . . used
jamesr1
What about the alternator?
peacekeeper6
no it wasnt even belted up at the time.
