Well I got all the title stuff worked out, so I bought the manuals from Ken Cook and I've started slowly to go through the motor. I've read a ton on the forum including "Awakening a Sleeping Outboard" and the engines "Top Secret File" among other online stuff.
I'm not very happy with the Ken Cook manuals, which is supposed to be a copy of the originals, the service manual seems very general. Not what I was expecting. These motors seem very complicated to me as a newbie and I'm not sure the service manual will give me the help I need.
I drained the lower end oil and it had water in it. I removed the cover and evrything appeared good, no metal bits or pieces, no corrosion. To me it seemed like it all looked very good. I removed the entire lower end tonight and looked at the water pump. The impeller looked very good. I'll probably still replace it, but it looked good. I removed the flywheel and was suprised to see that the coils, points, etc looked brand new. I'm not sure if someone recently replaced them, but I'm encouraged with what I'm seeing, but I've got a lot to learn. I removed the carb and it's just sitting there, plan to rebuild. All the wiring and fuel lines will need to be replaced.
The one thing that's on my mind right now is the water in the lower gear case. It seems that the parts manual shows about three different seals, not counting the ones on the drain plug, vent plug, and pivot head screw. I'm a little confused looking at the parts manual trying to figure out what seals to replace. Is there a kit available where you get all the seals you need and would that be the way to go?
The plans is as follows:
1. Pull the lower unit and replace the water pump impeller.
2. Change the lower unit lube and fix leak in l/u.
3. Rebuild the carb.
4. Convert to a fuel pump, but after reading everything here I'm still a little confused on how to get it done.
5. Replace fuel lines.
6. Pull the flywheel and clean and set the points and maybe replace points and condensors.
7. Replace ignition, battery, and other wires.
8. Give any grease fittings a fresh shot of grease.
9. Fire it up
So any advice or thoughts would be greatly appreciated. I have a feeling I may wear you guys out trying to get this motor running. I think I've got a pretty good one, but I'm a little intimidated.
9. Fire it up
