Re: 83 70 hp evinrude idles but dies adding throttle
ok been gone for a bit i did the carb thing no help found the bottom cylinder low on compression 75psi did a complete rebuild all cyliners at 130psi same outcome i was reading that the center carb is different form the other 2 top and bottom? also how do you sync the throttle and carbs and timing advance. how should the throttle cable be set before this is done and one more thing thanks for being patient the electric primer when it is pressed should it pump or just allow a path for the fuel to be sucked into the carb. this motor has been a nightmare in agrivation time and money, one more clue if any of the 3 plug wires are removed when it is running the motor dies
any help is greatly appriciated
thanks
tim
these are fixed jet carbs
thanks
tim
