Slow Ride
- Sep 17, 2011
- 166
I noticed a change in the way my motor sounds. I have only owned it a few months but I'm almost sure it is quieter when I run it while out of the water. It seens to run normal when on the water but is idling rougher than I remember it being a week or two ago. I noticed that the port side cylinders are not firing. I discovered this by pulling the plug wire while at idle. No change in RPMs or sound. If I pull either of the starboard side plug wire the engine stumbles and dies immediatly Ok, I pulled the plugs out and put them in the plug wires. I cranked it up and no spark on the plugs and no gas coming out of the hole in the cylinder either? When out of the water the motor is slow to build RPMs. If I open the throttle wide open, it takes 3-4 seconds for the rpms to get to 5500. So, I put it all back together and went to the water. I put it in the water and as ussual it ran rough at idle. When I push the throttle to wide open, the RPMs come up slowly for about a half a second and then "BAM!" IT takes off like a rocket and runs like nothing is wrong! I never noticed this before but it could have been this way all along, although I'm sure it was louder out of the water in the past. Is it possible that it sinces the torque load and turns the two cylinders on and then back off when not needed? It is an Optical Ignition System. Does this make a difference?
