Oil injection system removal
novi_4u
Oil injection system removal - I wanna know if I need to use block off plug (dummy shaft) on a 2005 Mercury 200XL Saltwater (with carbs) to hold the brass bushing at the end. I know that this is an issue in older model and I just want to confirm this for a later model. Thanks in advance!
Faztbullet
Re: Oil injection system removal
If its the 2.5L block ,yes your wll need it, part number is #43453 and o-ring #32509......
novi_4u
Do you know if the nylon gear (the one that drives the oil pump shaft) is still used on this model? thanks!
