I have twin VP 5.7GXiD DuoProp sterndrive setup in a 2003 Doral 330SE (Elegante). The upper steering pivot seals leak on both engines at the rate of approximately one drop every two seconds (the water leaks around the seal, flows forward on the housing, then back aft and down, and finally comes forward again on the exhaust Y and drips down into the bilge). They have leaked for the two seasons I have owned it, and I have to assume they've leaked since new, because of the configuration of the boat. The VP specs on how much of the sterndrive transom bracket should be above the waterline show at least a few inches more "reveal" than the 330SE, which sits low in the water. Unfortunately, this is normal for the 330SE. Apparently, the steering pivot seals were not meant to be continuously submerged. Regardless, this winter I am finally going to resolve this problem. Does anyone have any experience with the method, procedure, repair, or improvement of a similar situation?
