Re: evinrude 9.5 hp sportwin yr and model unknown wont stay on
This engine only has a low speed needle and fixed high speed jet. It is also notorious for exhaust leaks through the seal in the exhaust housing, which makes it get a lot of smoke up into the cowling wihle running in a test tank. You will have a hard time setting the idle that way. Unless you have a good breeze or a fan blowing the exhaust away from the carb throat, set the idle with the motor on a boat, in the lake, in forward gear.
Oh, BTW, if you think you may have a problem with air leaking in thru your welch plug that you drove in too far, dab some clear nail polish around the plug to seal the outer edges.
