I recently purchased a 2005 Sky Supreme V220 with a 5.7 Mercruiser. Should the stero turn on when the boat is not running? I have two batteries in the back and have checked both and they are good. I can't run any of the accessories when the engine is not running and the ACC togle switch does not lite up when activated. The horn also is inop and the ballast tanks won't seem to fill. It sounds like a fuse or fuses.
Any suggestions?
Any suggestions?
