Frozen flywheel nut on 1983 mariner 50hp motor
ARTHURRUF
I have used 8o foot pounds to loosen this nut to no avail. Any suggestions? Will heating the nut cause problems? Thanks, Art
RandyJ
Master Chief Petty Officer
Re: Frozen flywheel nut on 1983 mariner 50hp motor
I would avoid using heat on any outboard powerhead. I'm sure others have suggestions but if it rust or corrosion PB Blaster sprayed on is a good nut loosener. Other than that I'd go with a pneumatic (air powered) impact wrench that will kick around 120 ft. lbs. or more. I don't have a clue what torque spec's are for flywheel nuts but I've had as much difficulty getting them off as I have getting lug nuts off of vehicles.
jim765
try useing an impact gun.if yoou have one to use.
jim765
also use some pt blater on it befor trying ,works for me.
Sunfish12
Tow it to a an auto repair shop. I'm sure they'll air gun it off for you at no charge.
ARTHURRUF
I solved my problem by using liquid wrench and letting it sit over night and then used 100 pounds of tourq. I did use heat on it the day before and melted the lock portion of the nut. Will get a new one. Thanks. Art
