Re: placeing stringers
That mesh will not work for your boat. I have never used West Systems resin but adding cabosil to any resin should not make it clump. Did you add the MEKP before or after adding the Cabosil? You should add before to get a proper mix IMHO. Add the cabosil gradually and not in one big dump.
I think he ment West "cabosil" and not resin ..
Weekender .. Sometimes ( most times ) cabosil will clump in the packaging. You have to Break it apart with your fingers ( or a flour sifter works GREAT *hint* ).
You will have to Mix and mix and mix and mix .. keep mixing and smashing those little chunks of cabosil until there gone if you dont De-clump it first.
Cabosil is not just a " put some of this in there and pour some resin and mix" thing. Its .. different then the usual fillers.
This is what I do. Put your cabosil in a paper cup ( bucket or dixie cup depending on how much you will need ). Put your hand in there and start to finger all of those chunkies until you really cant feel them anymore. Then I mix the resin in until I have the desired consistency. Let the mix "Induct" sorta speak for 10 min. .. then I batch off what I want to use and add the MEKP. Mix the MEKP well with the putty and apply.
With a Small nail hole I would just die grind a bit around the hole and apply/pack in the Cabosil mix. ( no glass ).
YD.
