Ok here's the deal. I have a Johnson 50 2 cylinder with 2 carbs. One carb is plugged up so it only runs on 1 cylinder so I can't run it as it is. I'm going to rebuild the carbs this winter but need to properly fog the powerhead. Should I spray some 2 cycle oil in the cylinders and rotate it by hand and call it good? Any suggestions?
