slickster2
- Jun 16, 2010
- 74
have a johnson 10 horse its an oldie!!!!!!!!!!and it runs A1 but keep jumping out of geer looked it over and don't see why nothing broke thanks
hi there any pix of the clutch dog as I have no book and have know idea where it would be thanks
Your mod number should put is as a 56, here the parts diagram:
http://www.marineengine.com/parts/v...evinrude-johnson/ITEM_2746/ITEM_274600001.htm
Also, those old 10s have a spring clip and detent arrangement that holds the shift rod in place. I've seen a few that have had the spring clip bent or moved out of place (loosened). If you don't feel a positive engagement when shifting, that may be your issue - and you have to pull the gearcase apart to access it...
how do you figure this? He gave his model number as an 00-12. Johnson did not make an 00-12. They did however make a QD-12 which is a 1951-52 10 hp motor.
Took it from Marine Engine catalog site:
http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1956&hp=10
Together with the info he gave in an earlier posting:
'hi there the modle number is 00-12 and serial number is 111993'.
ok took the numbers right off the plate on the motor no nothing about it and can't find repair manual
