When I first got my boat running on the muffs in the driveway, I checked the oil in the upper unit and it was milky. I noticed that there wasn't a seal under the head of the screw-in dipstick, and as the dipstick is right on top and the boat had been sitting for several years, I figured that it was possible that water had leaked in around the dipstick itself. Before water testing the boat, I drained and refilled the oil in the upper unit with BRP HiVis lubricant and added the correct seal. I tried my best to get all the old oil out and the new oil looked fine once I got the level correct.
After today's test run the new oil is milky again, so clearly I have a seal leaking somewhere.
According to my Seloc manual, (I know - but that's what I was given) I need to remove the outdrive, pressurize it to no more than 15psi, then submerge it to determine where it is leaking. Then replace the leaking seal.
Should I do that? Or given that this boat is 25 years old, the previous owner had it winterized only and did no other maintenance, and it hasn't been run for several years - am I better off to just replace all the seals in the upper unit as well as the impellor and anything else that is in there?
I don't want to sink too much into this boat, but once I'm in there it makes sense to me to replace all the seals the first time through and assume that new seals all around will resolve the current leak as well as preventing future problems.
Thoughts? I haven't priced the parts yet, but I'm not expecting the parts cost to be prohibitive and I'll be doing the work myself.
Anything to watch out for while doing the work?
Anything else to inspect, lubricate or replace while I have the outdrive off?
Thanks
Big_Eddy
Thanks
Big_Eddy
