Re: Bottom paint remove?
I have to disagree with a majority of the posts, with the exception of Fireman. Regardless of how old the boat is or long it has been painted or whether a barrier coat was applied, the aplication process hammered the gelcoat. If it was done properly, then most bottom paints recommend an throrough sanding with 80-100 grit sandpaper. No matter how you take the paint off, the process is going to further beat up the gelcoat. I have seen hundreds of boats remove old bottom paint and have NEVER seen one that looks anything other than beat up. Once the paint is removed, it will look horrible. As for blasting. I've also seen many. I had my boat done a few years ago. Blasting will also beat up the gelcoat in the process.
As fireman said, a white awlgrip type paint or a whit bottom paint will be your best bet.
