Re: when I use my choke it blows my starter fuse 115etl77s
Sorry guys for not replying to your valued help but i have been away with work for some time & haven't had any playtime,I have had this problem resolved, turns out had a number of problems here the main fuse to the starter solenoid was only 10 amp,the second hand choke solenoid was also faulty, turns out the ohms reading across the coil should be 6-8 ohms, spent 1 hour back at the wreckers testing through a box of them to find one in the right range, much to the surprise of the supplier,came home & just finished putting it all together & now works like a charm.
So once again thanks for all your help & I'm off fishing as it is a great day outside today
