Testing of electronic ignition.
LukeMc
Hi, I have a mercury 1100 110hp motor from 1967-68. It was running but wouldn't idle down so I decided to put new carb kits in. To do so it required I take off the electronic ignition. I did and when I put it all back it wouldn't run. I took it to my local mercury dealer his mechanic took a quick look and said I had hooked up the wires right so he said it must be the electronic ignition unit.
Is there a way of testing these units????
I feel it is more likely the wires as some are quite corroded much of the insulation even coming off. I don't want to purchase a new electronic unit only to find that's not it.
If any one knows anything about these motors any imput you can add would be greatly appreciated. Thanks LukeMc
Laddies
Banned
Re: Testing of electronic ignition.
Here's the CDI test
