Can you use an MC-1 outdrive on an Alpha One Gen 1 Gimbal and transom assembly? I have an 87 Fourwinns 160 with a 3.0 181 engine. It had a 1.98 Alpha one on it that was ran without lube and shredded to pieces!
I have read about people putting the Alpha One on the MC-1 housing..but not the other way around. Is this possible if the gear ratios are the same, or close for that matter?
The drive I had was 1.98 and I think the one I found (for a good price, which is why I ask) is a 1.84 (possibly 1.98 as well..).
Thanks for the advice!
